Arp patch will not stop
« on: September 06, 2016, 10:55:34 AM »
Hello... I am new here!
I have an arp patch that I have tweaked. The problems is that the patch will not stop sounding, as if the arp was latched. Even when I do a midi reset (all midi notes off command) in Cubase 8 it doesn't stop. As soon as I load the project in Cubase the sound from the patch starts immediately, before any keys are played or the play button in Cubase is clicked.
The patch is loaded to the Mopho buffer from the VST editor, it is not stored in a bank on the Mopho itself.
Any ideas?
Thanks,
Sayer
« Last Edit: September 06, 2016, 11:02:50 AM by sayersweb »
panic
Re: Arp patch will not stop
« Reply #1 on: September 30, 2016, 05:09:15 AM »
My first guess would be that you turned up the VCA level in the patch.
« Reply #2 on: November 29, 2016, 02:44:56 AM »
Maybe not likely, but check the MIDI clock settings too. I had the opposite happen, I had set MIDI clock to in/out, and the mopho wouldn´t play until it received clock messages.
« Reply #3 on: December 06, 2016, 09:04:27 PM »
Thank you both for the suggestions, I will try them out. I totally forgot that I posted this question a couple of months ago. I ran into the same problem with the Mopho this week.
