Distance between rubber feet?
« on: May 28, 2023, 05:00:10 AM »
I'm considering whether a Take 5 will fit neatly onto a particular keyboard stand of mine (currently home for a Moog Little Patty with eurorack modular above).  What I need to know is the distance between the Take 5's rubber feet, both front and back.  I'd be super-appreciative if someone could measure that for me.
I'm thinking of swapping out the Moog for a Take 5, which I feel would be a lot more useful to me right now.  Also helps that it sounds great and the V2 update has only made it even better! :D
Thanks in advance.
Ian
kpatz
  • 165
Re: Distance between rubber feet?
« Reply #1 on: May 28, 2023, 07:33:34 AM »
The feet are 20 inches apart side to side, and 8 1/4" front to back.  So they form a 20"x8 1/4" square.  The feet themselves are 5/8" diameter.
But, if they don't align with your stand, you can always get some stick-on rubber feet and put them where you need.
EDIT: Adding metric measurements:  50.8cm x 21cm, feet are 1.6 cm diameter.
« Last Edit: May 28, 2023, 07:59:10 AM by kpatz »
« Reply #2 on: May 28, 2023, 09:28:52 AM »
That's great.  Thank you for checking that for me.
Looks like a near-perfect fit on my stand. :)
