Updated 1.0.0.7. OB-SX bank not working properly
« on: May 21, 2023, 11:34:48 PM »
After updating. and full calibration etc. the OB-SX bank is not functioning properly.  I have to press each key twice for the note to play a sound.
Any recommendations?
Re: Updated 1.0.0.7. OB-SX bank not working properly
« Reply #1 on: May 22, 2023, 10:34:07 AM »
If i remember correctly all the sounds in that bank are set to full panning in ping pong mode? So you may only be hearing one channel of the stereo field for some reason. Check your cables and global stereo settings. A quick check to confirm would be to go into a patch on page 2 parameter 15 or 16 i think it is and set the pan mode to mono and see if that gets all the notes sounding? then that would confirm the issue!
« Reply #2 on: May 23, 2023, 09:26:27 AM »
Wow you are absolutely correct! :) Haha
Thank You!
