Morphing issue.
Morphing issue.
« on: April 24, 2023, 10:15:32 AM »
New Pro 3 owner here. This is my first analog synth so I am a novice here. My unit does appear to have the latest update, and I have tried setting up a couple of morphing sounds, but it never seems to get there. I am choosing 'all parameters' and the sequencer value knob to do the switch, but when I morph, I get a sound that is nothing like the target sound. Am I missing something?
Re: Morphing issue.
« Reply #1 on: April 24, 2023, 11:06:31 AM »
I did try using different encoders, just in case I am not getting the full morph, but they all go to 255, and I end up with the same unusable sound.
Re: Morphing issue.
« Reply #2 on: April 24, 2023, 12:24:34 PM »
I think I have figured it out? You can only morph between compatible patches (for want of a better explanation). Basically, patches made of the same stuff?
  • 1687
Re: Morphing issue.
« Reply #3 on: April 24, 2023, 02:21:57 PM »
There are some limitations, like you can't move between filter types or wavetable waveform selection. But even in this scenario, you should be able to morph between non-excluded parameters.
« Last Edit: April 24, 2023, 04:11:35 PM by chysn »
Re: Morphing issue.
« Reply #4 on: April 25, 2023, 12:46:29 PM »
The only way I can get a usable result is if I morph to a slightly modified version of the same sound.
