Instructions for loading samples
« on: April 01, 2023, 02:48:07 AM »
Are there instructions for loading user samples anywhere? I cannot find anything apart from the section in the user manual which hasn’t been updated since the user sample capability was launched (from what I can see anyway).
I go to Globals then Update Library but then get the message “No files found on USB stick to replace with”
Has anyone got any instructions or advice regarding this?
Shaw
  • 1185
Re: Instructions for loading samples
« Reply #1 on: April 01, 2023, 09:00:16 AM »
I uploaded a sample / preset pack here:  https://forum.sequential.com/index.php/topic,4169.0.html
Included in that download is a PDF I put together that explains the process.  That PDF might help you even if you don’t want the presets.
« Reply #2 on: April 01, 2023, 04:57:56 PM »
I didn’t change the Library value to User in the Globals menu.. works now though thanks to your instructions.
Thanks so much for pointing me in the right direction, much obliged!
Shaw
  • 1185
« Reply #3 on: April 01, 2023, 08:02:20 PM »
Glad you got it sorted!
