Prophet 5/10 SysEx Format
  • 1812
« on: March 15, 2023, 07:54:21 AM »
Sequential no longer publishes this stuff in the back of their manuals. Does anyone have the Prophet 5/10 Rev 4 system exclusive voice format? I'll reverse-engineer it if I have to, but I was hoping someone could save me some time...
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
Re: Prophet 5/10 SysEx Format
« Reply #1 on: March 15, 2023, 12:25:45 PM »
Channelizer on Gearspace will know.
  • 1812
« Reply #2 on: March 15, 2023, 03:34:13 PM »
Thanks! I don't have much of a foothold in Gearspace. In fact, I just signed up for it today! So I might lurk for a bit before reaching out to anyone.
« Reply #3 on: March 15, 2023, 05:18:13 PM »
I’m in touch with him privately anyway so have asked on your behalf.
  • 1812
« Reply #4 on: March 15, 2023, 08:36:30 PM »
I very much appreciate that!
« Reply #5 on: March 16, 2023, 03:24:32 AM »
  • 1812
« Reply #6 on: March 16, 2023, 05:45:59 AM »
Is this document insufficient?
It sure is, thank you! And please pass along my thanks to your friend!
« Reply #7 on: March 16, 2023, 06:33:54 AM »
These documents are all accessible via the sequential support page here, which is where I found it:
https://www.sequential.com/support/
  • 1812
« Reply #8 on: March 16, 2023, 06:48:10 AM »
Ah! And here I was, looking in the manual!
I was actually really impressed that somebody took pains to duplicate the exact "back-of-DSI-manual" style.  :)
  • 1812
« Reply #9 on: December 17, 2023, 06:12:29 AM »
The document discussed here has gotten me pretty far. I know some NRPNs have been added since the document release (Q compensation, Prophet 10 layers). I was able to figure out the Q Comp NRPN by changing it. But I don't have a Prophet 10, so I have no way to figure out the new layer parameters (Layer B program, Layer A and B levels, Split) by myself.
Does anyone know the NRPNs for these parameters, and associated ranges?
« Last Edit: December 17, 2023, 06:55:35 AM by chysn »
  • 1812
« Reply #10 on: December 28, 2023, 09:53:51 AM »
I asked Sequential Support about this, and I'll put the information I received here, in case anyone else needs it. All NRPN numbers and ranges are in base 10.
Layer A/B Select
NRPN: 80
Range: 0-1
Type: Enum (Layer A, Layer B)
Notes: She did not specify what value corresponds with what layer, but 0=A, 1=B is a strong likelihood
Bi-Timbral Mode
NRPN: 89
Range: 1-3
Type: Enum (1=Normal, 2=Stack, 3=Split)
Notes: The structure of this enum contradicts Sequential's normal 0-indexed praxis. I assume that 0 would also be treated as "Normal" because that's what NRPN 89 is for all Prophet-5 programs.
Split Point
NRPN: 95
Range: 36-96
Type: MIDI Note Number
Notes: This note number range covers the Prophet's keyboard range.
Layer B Program
NRPN: 91
Range: 0-39
Type: Same as sysex voice message program number (0-7=bank 1, etc.)
Notes: Apparently there's no NRPN for group number. She says:
"Changing the Layer B program involves two steps:
-Change bank/program: NRPN 91, value = 0-39 (0-7: bank 1 programs 1-8, 8-15: bank 2 programs 1-8, 16-23: bank 3 programs 1-8, 24-31: bank 4 programs 1-8, 32-39: bank 5 programs 1-8).
-Change group: set CC 32, value = 0-4 (Group 1-5)."
I don't really understand, then, how group number is stored as part of the voice data. I'm assuming that the Layer B program must live in the same group as the Layer A program, though, as CC32 is just the normal bank change MSB control message.
Layer A Volume
NRPN: 88
Range: 0-127
Type: Integer
Layer B Volume
NRPN: 96
Range: 0-127
Type: Integer
  • 1812
« Reply #11 on: December 30, 2023, 01:39:48 PM »
Is anyone able to upload a sysex Prophet-10 voice dump file that uses a split point? That would really help me out a lot. Especially if the Layer B comes from Groups 2-5 (not Group 1).
558
« Reply #12 on: February 10, 2024, 04:27:28 AM »
I can do that. Here is a file of a program 4.15 with 2.1.8 from the previous version of the firmware.  Also put in several other incremental in either group, bank or factory property.  all are labeled with the a b numbers as name.  I have not updated the firmware.  Don't have any plans to.  Don't know if these are compatible with the new firmware.
« Last Edit: February 10, 2024, 06:00:42 AM by 558 »
Another satisfied Prophet 10 owner
  • 1812
« Reply #13 on: February 12, 2024, 12:21:15 PM »
I can do that.
Thanks a ton! This is awesome info, and helped me address an unknown bug.
558
« Reply #14 on: February 23, 2024, 04:53:21 AM »
Say what you got the nrpn info out of this?  What you use that info for anyways man?
