Voice Fails
Voice Fails
« on: March 02, 2023, 12:13:40 AM »
I installed the latest Firmware, did a Calibration Reset and tried to do a full Recalibration.
Calibration Proceeds, until a Screen appears reading:
Osc Voice Fails:
3320 Voice Fails:
SEM Voice Fails:
VCA Voice Fails: 7
Then it hangs and i can't do anything anymore. Powercycle does help and it returns to normal,
but shouldn't a full Recalibration return to the normal home screen, instead of hanging at this screen?
Starting Calibration again, get's me to the same screen again...
Is this normal, and is it ok if i just Powercycle once i get to this Screen?
« Last Edit: March 02, 2023, 12:17:59 AM by edwinstar »
Re: Voice Fails
« Reply #1 on: March 02, 2023, 04:07:20 AM »
A quick update. I repeated the Calibration Process several times, and after some more fails, suddenly all went well and the Synth returned to the "Home" Screen.
So for me, the problem is solved, but i still wonder if it is normal that the Full Calibration fails several times.
Re: Voice Fails
« Reply #2 on: March 02, 2023, 07:20:39 AM »
I'd contact support if it happens again. I had a similar issue with SEM filters failing calibration that was apparently a known issue with some firmware versions. Had to do the newest (unreleased at the time) beta OS that they provided in bootloader mode on their instructions to fully fix it. All good now though!
Re: Voice Fails
« Reply #3 on: March 02, 2023, 07:35:42 AM »
Thank you! Good to know that it's something software related!
