Portamento Match = Off (More "off" please!!)
« on: February 19, 2023, 11:27:35 AM »
Believe it or not, I bought the OB-X8 in the hopes of getting ONE particular sounds that I identified with the OB series.  It's the "detuned" portamento sound where all Oscillators arrive at the target pitch at different times.  The OB-X does have a switch for this "Portamento Match = Off", but its way too subtle at fast speeds.  You really can't even hear the effect.
I fell in love with this sound in the 70s with a number of Styx songs that made use of it and always wanted a hardware synth to achieve this sound. While I do love the OB-X8 a lot, I'm massively disappointed that I can't achieve the OB sound that I've always dreamed of.
Attached are two sound files.  One is a software synth emulating the sounds I'm expecting (SonicProjects OP-X) and the other is the OB-X8.   On the OB-X8, you really can't even hear the drift between the Oscillators.
Would it be possible to Change "Portamento Match" into a value instead of an On/Off switch so we can dial in the amount of drift we want?  This would make my sonic fantasy come true!
Kind Regards,
Bill
Bill Hubauer
Neal Morse Band
We Came From Space
Re: Portamento Match = Off (More "off" please!!)
« Reply #1 on: February 19, 2023, 03:09:00 PM »
There's a variable setting under Page 2 that has been there since day one.
« Reply #2 on: February 20, 2023, 06:48:22 AM »
Thanks so much for taking the time to reply, but I see no such setting.   The only relevant setting I see is "Portamento Match = on/off", which does exactly what I want, except that its way too subtle at fast speeds.   Listen to the attached samples to hear what I'm talking about.
thanks
Bill
Bill Hubauer
Neal Morse Band
We Came From Space
« Reply #3 on: February 21, 2023, 10:32:47 AM »
I don't have an OB-X8 so may not know what I am talking about, but have you tried turning up the Vintage knob and detuning Oscillator 2?
I assume this is a Unison patch.. is there an overall Detune function on the OB-X8? Try turning that up too if it's on there.
« Reply #4 on: February 21, 2023, 12:23:24 PM »
I really thought the vintage knob would probably do the trick, but it doesn't have any affect on the Portamento Match feature (that I can hear).
Again, I want to emphasize that the OB-X8 does have the feature I want, it just doesn't sound the way I expect at fast portamento speeds.    I want to be able to add more "off" to the Portamento match off.... meaning increase the variation between the oscillators, so that at fast port speeds I can hear a bigger difference between the oscillators.
Bill Hubauer
Neal Morse Band
We Came From Space
« Reply #5 on: February 24, 2023, 10:12:35 AM »
Try the voice detune
It's the same behavior of the vintage models esp the OB-X which is where it originated.  As the portamento gets longer, the mismatch is more prevalent.  You won't hear much mismatch at fast portamento.  A short delay will do the same effect though.
« Reply #6 on: February 27, 2023, 12:30:46 PM »
Which Styx songs are an example of this portamento sound?  Is it the Fooling Yourself solo or Lights intro?  I will try to see if I can dial it in
« Reply #7 on: February 27, 2023, 04:11:57 PM »
Fooling Yourself
Miss America
Renegade (during breakdown)
While it's not an Oberheim, DDY pulled off a similar effect on Sweet Madam Blue using an ARP ProSoloist through a delay.
« Reply #8 on: March 02, 2023, 05:09:42 AM »
Yeah, i know what you mean!
It should be possible to make the Voices drift at different Speeds and Ramps. Listen to how cool it sounds on my (badly calibrated) old OB-X. It would be great if individual portamento time per voice would be affected be the Vintage Knob!
I added two files, OB-X8 and my original OB-X.
