Send transport (play) to both A and B layers
« on: January 14, 2023, 01:43:41 PM »
Hello guys, I found 2 similar questions here, but the answers not exactly cover mine request))
So.
Is it possible to send simultenously transport (play) message for bot layer A and B?
So I could start playing sequneces on both layers sending midi transport signal from external source.
The layers are splitted. A have arp, B have poly sequence.
At the moment I need to press "edit B layer" to make it's sequence play.
Probably I can swap them, but I hope there some more intelligent way.
Oh, I also tried to stack them, but this turns to some extra notes and overall craziness)
Re: Send transport (play) to both A and B layers
« Reply #1 on: January 14, 2023, 11:27:41 PM »
From manual
"The sequencer requires a note to be gated on — that is, played from the
keyboard or via MIDI — in order for the sequencer to run. There is no
dedicated start or play button and it doesn’t respond to MIDI start/stop/
continue messages. But it can still sync to an external clock."
Multi mode have to be on
"15 . Multi Mode: On, Off—Multi Mode allows separate MIDI control of
voices 1-8 and voices 9-16 on 16-voice systems. (On 8-voice systems
this is voices 1-4 and voices 5-8.) This enables independent, bi-timbral
control of the Prophet Rev2.
When Multi Mode is on, the Prophet Rev2 responds to MIDI data on two
consecutive MIDI channels — the base channel (selected in the Global
menu) and the next highest channel. "
If multi mode is on layer B should respond to channel 2 I suppose and also make layer B sequencer play when notes arrive.
« Last Edit: January 14, 2023, 11:29:16 PM by Autosynther »
« Reply #2 on: January 15, 2023, 04:37:37 AM »
From manual
yes, that's right, but I'd like to stay in stack/split mode. Without multimode.
And I certainly used note to start Arp, but for Poly sequencer you don't need note, it's just starts by "play" button from external sequencer. But only in A layer((( to activate play on B layer you should extra press "edit layer B" first.
And I'd like
