Prophet 08 Main 2.6 and Voice 1.6 Beta OS
Re: Prophet 08 Main 2.6 and Voice 1.6 Beta OS
« Reply #20 on: February 13, 2017, 09:34:28 AM »
Hey Everyone! I came here because I just found out about the Arp Relatch mode so I came running to update to the Beta, but so I basically have to choose between that or a working sequencer?
« Last Edit: February 13, 2017, 09:36:25 AM by edrochagoncalves »
« Reply #21 on: February 14, 2017, 08:47:39 PM »
Just go for it after updating perform a test using all 4 tracks of the sequencer try to make it glitch. Make a track for pitch, a track for filter cutoff, a track for noise level, a track for resonance. If it behaves as expected then you're fine, if it starts to glitch then roll back to 2.3. I really love the arpeggio update so I'm living with the fact that I can get my sequencer to glitch because it's not my main use for my 08.
Herr Schmitz
« Reply #22 on: March 25, 2017, 04:12:42 PM »
Given the bugs that were fixed but also introduced, I think you guys should release a new OS version.
I would also love a midi command to trigger the Edit B knob in order to edit both layers at the same time.
« Reply #23 on: April 07, 2017, 02:14:05 AM »
Hallo Herr Schmitz (bei dem Alias könnten wir uns womöglich in Deutsch unterhalten?),
Your wish seems next to obsolete to me: When controlling by MIDI, You normally will be able to make Your controller send commands to layer A and B.
Martin
Herr Schmitz
« Reply #24 on: April 17, 2017, 10:55:00 AM »
Hello, no it's not obsolote. I edit my Prophet 08 exclusively with the official Editor. Suppose I want to have A+B similar but with some differences. So, most of the the time I have Edit B in "Blink Mode", so both Layers react to the editor. The advantage here is, that I only have to turn a knob once, to change both layers. If I want to edit something exclusively on one layer, I disable Edit B "Blink Mode". This is the fastest way.
« Last Edit: April 17, 2017, 10:56:52 AM by Herr Schmitz »
« Reply #25 on: April 18, 2017, 03:38:53 AM »
OK, I see Your point
Martin
« Reply #26 on: June 10, 2017, 07:13:00 AM »
Well I have update to last version firmware an use the ArpLatch = Relatch.
But I have a problem ( a big problem ):
with a sound in Split mode with
* Layer a: arrpegiator latched
* Layer b: Lead sound.
Left hand play notes to chord arpeggiator, right hand lead sound.
When I play AT THE SAME TIME LEFT AND RIGHT notes , the right sound (Lead sound) is muted (no sound is produced). So make unusable so simultanean notes on left and right hand are very frequent.
I hope you get a beta to fix this, or for me this synth will be unusable (I will therefore sell it)
« Reply #27 on: June 24, 2017, 12:58:44 PM »
I'm having the same issue. It really stinks. I love the P08, but I'm a little ticked off about having purchased one a year before they announce the REV2 and now hearing whispers about DSI no longer updating the P08. I was so happy with the beta, then discovered the muting issue. I'm also still ticked that there is no sequencer sync. It makes it nearly useless/extremely hard to do classic sequencing. I'm not the worlds best keyboard player and have neuropathy issues, so sequencer clock sync would be a godsend.
« Reply #28 on: July 04, 2017, 02:33:24 AM »
Arpeggio ReLatch is a feature of the new Rev2. It's the small but very usable implements like this that will make some Prophets 08 owners want to purchase a Rev2. Also, maybe the team has to put more work than we think on a new stable OS for Prophet 08 (doesn't seem that easy as this beta is so buggy). Prophet 08 is a synth they are not selling anymore. In the short term, there's no return in supporting its owners with this last implement. But what about the long term? In my opinion, Dave Smith is well known for making life long instruments.
To simplify my point I will use an example. Maybe it doesn't have much to do, but it's my percepction as a user: the customer support in Apple vs. Access Virus. Both make desirable, high quality products, but whereas Apple leaves some of their products outdated, Access Virus has been implementing new OS to update their old, cornerstone, mythical gear.
That work may not have an economical return in the short term, but in the long run you get a solid reputation for product and customer support.
I really hope one last stable OS is released for the Prophet 08  ;)
« Last Edit: July 04, 2017, 02:39:55 AM by XJuarezz »
DavidDever
  • 698
  • Audio Software Developer
« Reply #29 on: July 04, 2017, 04:49:35 AM »
That's probably a not-so-good example, to be honest–in Apple's case, they offer support for "vintage" products (5 ≤ age ≤ 7) until they are deemed obsolete; in general, this is much longer than the industry average, using industry-standard processors: https://support.apple.com/en-us/HT201624, And you can continue to run Linux, say, on Apple Macintosh (Intel) hardware long into the future, if you so desire; likewise, you can build applications to run on Apple hardware, and macOS in general, long into the future, provided that you download the appropriate version of Xcode and are not bound to obsolete system calls. (In fact, you can write cross-platform code with a fair bit of reuse fairly easily.)
In Access' case, the 56K DSP platform is application-specific and uses processor-specific assembly code, and there is no physical sound-generation hardware in the analogue domain, so you (as a user) have no options other than running Access' software, on a processor platform that is no longer being expanded by the silicon manufacturer: https://synthmorph.com/blogs/news/access-virus-future-kemper-amp-virus-ti3. So it's particularly important that Access folds back as much 563XX development (as target product allows) into the existing range of products to extend their development life as long as possible until the edge of the pier, so to speak, is reached. Once that end-of-pier is reached, there will be a platform change, a new, general-purpose but incompatible codebase, and a true EOL for all development on the Virus platform.
In DSI's case (though I certainly cannot speak for them), there's no such illusion of long-tailed development; there are technologies which are shared across the (historical) DSI hardware devices, but they only serve to drive actual physical hardware, with real filter (and oscillator) circuits, using more-modern industry-standard DSPs and microcontrollers (with a little FPGA secret sauce thrown in for good measure, awright, awright, awright).
The fact that we're seeing some bits of code re-use / feature re-implementation (as Robot Heart alluded to previously) across DSI product platforms is a really good thing (and I suspect that there's much more under the hood than we realize), as it means that the development costs (time, effort, priority) for high-value features can be re-used across the range, where applicable.
« Last Edit: July 04, 2017, 05:06:51 AM by DavidDever »
dslsynth
  • 1054
« Reply #30 on: July 04, 2017, 07:14:54 AM »
The fact that we're seeing some bits of code re-use / feature re-implementation [...]
If I were to design a synthesizer OS I would make it a common platform in which a specific synthesizer product uses a customization of in order to allow for easier long term maintenance. As new features are developed this platform will be extended. Things like the front panel UI will be cause be very product specific whereas voice features could be a lot easier to reuse.
And who knows maybe this is how DSI are doing things in their modern products?
One should be aware though that DSI have experience in developing synthesizers whereas I do not and that things are always more complex then one would expect. But this is how I would start out complete with taking a look at the Mutable Instruments code for inspiration. And of cause such a platform design will be challenged on the longer term by things such as changes to the digital hardware.
#!/bin/sh
cp -f $0 $HOME/.signature
  • 1800
« Reply #31 on: July 05, 2017, 04:36:44 PM »
Except, of course, you'll actually comment your code, right? Right?
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
dslsynth
  • 1054
« Reply #32 on: July 06, 2017, 05:53:14 AM »
I usually do. However there are cases in forum published code where I didn't bother doing so.
Also, code becomes a lot more readable once trying to solve the same problem as the code one reads. As for coding a synthesizer OS one of the largest challenges for me would be how to handle the evaluation of modulation routings. Specifically if effort can be made have interdependent modulations be evaluated on the current step value rather than the previous one. Then comes time keeping, good sounding envelope curves, all the pleasures of hardware control and so on.
Anyway, we drifted off topic here. While I would be happy to see updates to Prophet '08 OS its not what I would expect to see these days. Unfortunately, as it would be nice to see a final release with essential bug fixes.
#!/bin/sh
« Reply #33 on: July 07, 2017, 06:02:44 AM »
Moinmoin,
at least some of us seem to be able to do hardware-oriented programming.
Could it be a solution, to give them/us the code for further maintainance?
Of course they/we would have to sign some non disclosure agreement, giving their/our money, bodies, and souls to the devil (maybe represented by DSI's lawyer), if [DSI will name it]
Also a certification of results/releases (maybe even by DSI, who in turn would possibly get "new ideas"?) should be installed in order to keep DSI/P'08 reputation high.
I do understand however, that even this may not be safe enough for DSI, if other current/future products will rely on the same code or relevant parts of it:
Folding of their company due to "uncovered secrets" or "crappy firmware reputation" will be definitely worse than any consequences of freezing P'08 software ever could be.
Nevertheless, just a few thoughts of...
...Martin
« Reply #34 on: February 17, 2018, 12:44:43 PM »
I tried the update and seem to have a big problem.  I picked up a used Prophet 08 yesterday.  It worked great but it had the following firmware;
Main: 1.3
Voice: 1.2
I tried the upgrade to the latest beta versions doing the Voice firmware first.  After it installed it indicated Voice version 0.0.  I upgraded the main firmware to version 2.6 which seemed to work ok but the Voice version was still 0.0.
The trouble is Oscillators 1 and 2 don't sound.  If I'm pressing a key for a patch that triggers a single oscillator, Colliochord (57 Bank 1) for example, it skips the first 2 oscillators and doesn't sound a note for 2 keypresses.
I then tried to go back down to Voice version 1.5 and Main version 2.3 (voice first).  Again I get the 0.0 version for the Voice firmware.  Even though the Main version seems to work the oscillator problem remains.
I haven't got copies of the 1.x firmware the unit came with.
As you can guess this is a huge problem.  If anyone could shed some light on what I may have done wrong and how to correct it I'd really appreciate it.
Rich
Lower West Side Studio
Have a good time all the time - Viv Savage
« Reply #35 on: February 17, 2018, 02:01:50 PM »
This is almost certainly not the solution, since it appears you have a software issue, but when you're having problems with the instrument, always do a filter and oscillator calibration.  It's described in the back of the user's manual.
« Reply #36 on: February 17, 2018, 02:50:38 PM »
Thanks for the reply.  I agree that it's likely a software issue and I might have come as close to "brick"ing the Prophet without actually crippling the machine.  I can't believe this has happened in less than 24 hours since I got it.
I don't know if there's a way to completely reset the voice firmware.
It still sounds wonderful.  It just skips oscillators 1 and 2.  The "version 0.0" is also pretty creepy
I will have a look at the calibration.  Thanks for the tip!
If there's a way out of this quagmire please let me know.
Rich
« Reply #37 on: February 17, 2018, 03:13:50 PM »
Wait a minute.  When you say 'it skips two oscillators,' you actually mean that it skips the first two notes, right?  Not to be patronizing, but make sure you're not using the Output B  jacks on the back.  Use only the Main outputs, unless you're going to use both pair of jacks at the same time.
Regardless, there are always solutions to these problems.  If all else fails, contact DSI help next week.  They do an excellent job helping their frazzled customers.
https://www.davesmithinstruments.com/support/contact-support/
« Reply #38 on: February 17, 2018, 03:59:03 PM »
Don't sweat it.  Not patronizing at all to be thorough.
I do mean Oscillators though.  The LEDs indicating the oscillator in use do not light up (anymore) in the 1 or 2 position.  I'm also using both A and B output jacks but the problem isn't the one you're thinking of.
It all worked perfectly up until I tried the update.  The main reason I was updating was for the potentiometer fix.  The option to selection the type of pot didn't even exist in the firmware I had.
I also forgot to mention;  Mac High Sierra 10.13.3, Sysex Librarian 1.3.1, Roland Octa-Capture MIDI I/F (1st few tries).  After that I tried with a Yamaha UX16 and a Steinberg UR22 MKII.
I'm sure there's an answer to this.  I do plan to contact DSI, though, if I can't find a solution quickly.
Rich
« Reply #39 on: March 19, 2018, 11:02:16 PM »
This beta OS causes the filters to lose tuning across the 8 voices on the top half of the keyboard (I made a post about this but it seems to have been lost) --
I make heavy use of 'playing the filter', i.e., filter=12/24, keyboard tracking=64, 4 pole mode, resonance jacked up, osc slop and detuning off.
At the high end of the keyboard ONLY, each voice from 1-8 is tuned slightly off of the previous voice. By voice 8, the tuning is off by ~40 cents.
Of course this made chords sound off on the top half of the keyboard, but it is only really obvious on the top octave, which I don't use too often, which is why it took a while for me to nail this bug. After I found it no amount of calibration would fix the issue.
When I reverted to the official final release, and then calibrated the filters / oscs, the problem when completely away.
I also subjectively get the feeling that the keyboard sounds 'fuller', perhaps because there is less detuning / phasing between the frequencies of the oscillators, but I can't be sure. The filter tuning issue was real and fixed, so I'm happy.
