Beta OS 1.0.0.22 - Sequence transposition bug if unison is enabled
To reproduce the issue :
- Select a patch with unison enabled (e.g. the factory patch 103).
- Launch the sequencer
- Press Record and a note => the transposition is performed
- But as soon as the Record button is released, the sequence is stopped and the Record is enabled.
It's quite annoying.
When unison is disabled, the sequence transposition works as expected i.e. releasing the Record button doesn't stop the sequence and doesn't enable the Recording.
I don't know if this bug was already present in the 1.0 firmware.
kpatz
Re: Beta OS 1.0.0.22 - Sequence transposition bug if unison is enabled
« Reply #1 on: December 11, 2022, 03:47:46 PM »
In Unison mode there’s no need to press Record to transpose the sequence.  Just hit the key and it will transpose.
« Reply #2 on: December 11, 2022, 11:28:23 PM »
Wow !
Thanks for revealing this handy shortcut / hidden feature.
This should definitely be indicated in the User Manual.
However, I still think that pressing the Record button and a note should behave similarly when a sequence is playing, in unison mode and normal mode. This is what I expected from the User Manual and this would be also less confusing.
But again, the shortcut is great.
