Testing the new beta's LFO Slew Rate
« on: December 05, 2022, 02:41:59 PM »
Hey all:
I've been gaining familiarity with the latest firmware beta but don't understand how the new LFO Slew Rate feature is expected to work and Google has failed me.
In my ear experiments I can't discern an aural difference between using the LFO 1 Amount knob from changes made to the slew rate -- what am I missing? Maybe a use case would help?
kpatz
Re: Testing the new beta's LFO Slew Rate
« Reply #1 on: December 06, 2022, 12:52:49 PM »
Slew rate slows down the rate of change of the LFO output, like adding glide or a low-pass filter between the LFO and whatever it's modulating.
If you're using the triangle wave on the LFO it's not going to make much if any difference.  Try it on the square or S&H waveform to see what it does.  On the square, as you turn the slew rate up it will transform into a triangle or sine waveform.  On S&H, the transitions will be smooth instead of sudden.
You can also use it on the saw up or saw down wave to make a wave that rises faster than it falls or vice versa.
« Reply #2 on: December 06, 2022, 02:32:52 PM »
Thanks much -- I thought I tried other waveforms but I must not have. Appreciate the explanation!
