Why is this thing so so tricky when recording automation!!!
it spits out so many automation lanes from just one knob it takes me ages working out whats changing and its so difficult drawing it in on my daw..
It should only make one, but I have only recorded automation into the Pro3 sequencer direct.
It might be partially the Global settings on the Pro3? Are you using MIDI cables or USB? You should have one or the other plugged in I think.
Are you recording the automation into your DAW?
Maybe it's MIDI echo bouncing back?
