Annunciating Patch Parameter Setting
« on: November 13, 2022, 05:05:02 AM »
Does the OB-XA have some method of annunciating the patch parameter setting after being modified?
On the Prophet 6 (et al.), say you are modifying a patch parameter. When you hit the knob setting that is the same as the saved preset, a red dot lights up on the patch number led display. I use that feature A LOT. Is there something similar for the OB-X8?
If not, it would be great to have this in a firmware update, maybe brackets around the EDITED warning when the parameter setting is matched. It really helps the user to understand how patches are constructed and to quickly return parameter to saved settings. You can't just use your ears when it's something subtle like the Vintage knob.
