Hello everyone,
I have just bought a used Pro 3 and played on it last evening. The velocity of the keyboard seem to be very inconsistent, curve 1 and 2 for example are completely unusable because the velocity jumps between a difference of up to 30 in velocity althought I'm applying the same pressure. The only curve which I can use is curve 6 because it limits the velocity values to a minimum of 50 and it is hard to reach values over 111 without smashing the keys. But this takes away a lot of expression. Using the mod matrix instead of 'velocity on' helps, but the end it doesn't solve the problem that the values seem to jump a lot.
Anyway, I get the impression that something is off with the keybed. I'm a little bit disappointed because I lose a lot of expression. I asked another keyboarder which curve he is using and he said curve 1. This makes me very suspicious because for me curve 1 is completely unusable. I'm currently thinking about contacting the person who sold me the board and expressing to him that it's off, but I have no reference whether other pro 3s behave in a same way. What should I do?
