Take 5 Beta Main OS 2.2.0.9 and Panel OS 1.1.2
cbmd
  • 515
    • Sequential
« on: October 13, 2022, 05:20:29 PM »
TAKE 5 POLY CHAIN OS UPDATE
Please read the steps below for updating the main and panel OS on your Take 5. YOU MUST LOAD THE MAIN AND PANEL UPDATES SEPARATELY AND POWER CYCLE AFTER EACH INDIVIDUAL UPDATE COMPLETES.
1. Load Beta Take5_Main_v2.2.0.9.syx
2. Follow prompts on the display and power cycle when the load is complete. The Take 5 will boot, but the OLED will halt on the splash screen.
3. Load Take5_Panel_v1.1.2.syx
4. Note the text on the segment display. It will read "PrG" when the OS is writing to memory; do NOT power cycle yet. When the segment display changes to "rSt", power cycle.
The update process is now complete.
Note: The currently installed Main OS is displayed in the OLED from the Global menu. The currently installed Panel OS is displayed on the segment display when the CLK SYNC button in the Effects section is held.
ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!!
Not that we're expecting bad things to happen, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I hadn't backed that up..."
We do not recommend using the following MIDI interfaces for sysex transfers as we have had multiple users experience problems with them:
    Native Instruments Maschine
    Digidesign Mbox/Mbox2
    Digidesign 001/002
    CME U2MIDI
To check if the OS update was properly installed, press GLOBAL.  The OS version is displayed in the upper left hand portion of the screen.
If your OS update failed:
1. Update your MIDI drivers for your MIDI interface to the latest or last known stable version
2. Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
3. Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
4. In Windows with MIDI OX on Windows XP:  Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
5. Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with Sysex transfers and whether there is a solution specific to your interface
6. If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with sysex transfers
**INSTALLATION NOTE: It is recommended to reset globals after updating**
CHANGELOG
New Feature: Poly Chain
New Feature: Additional arp modes (PinkyUp, PinkyDown, ThumbUp, ThumbDown, Spiral, Leapfrog, Shuffle, ShuffleOnce, RandWalk, Chord)
New Feature: Whiplash arp timing parameter
New Feature: Violet noise
Take5_Panel_v1.1.2
Bug Fix: Improved encoder behavior
Take5_Main_2.1.0.2.syx and Take5_Panel_v1.1.0
Bug Fix: Fixed overdrive default param from TEO-5 to Take 5
Bug Fix: Various small bug fixes, optimizations, and improvements
Take5_Main_2.0.0.13.syx and Take5_Panel_v1.0.6
New Feature: Selectable TEO/Take-5 overdrive curves
Take5_Main_1.0.0.22.syx
Bug Fix: hung notes when using sustain in various cases
Bug Fix: Osc 2 level in filter bypass cannot be modded when osc level set to 0
Bug Fix: Osc 2 level in filter bypass modulation range is less relative to not filter bypass
Bug Fix: Osc 2 level cannot be modulated when filter bypassed and FM active
Take5_Main_1.0.0.14.syx
Bug Fix: Compare not working correctly after basic program instantiated
Bug Fix: Incorrect bank number can be displayed after exiting write when compare is active
Bug Fix: Write active, target program fixed when compare turned on/off
Take5_Main_1.0.0.13.syx
**IMPORTANT NOTE - If you saved programs in user banks 9-16 on the 1.0.0.10 OS, the programs will be pushed to the factory bank to account for the bug where updating from 1.0 OS caused program offsets.
Bug Fix: Compare does not work when write is not active
Bug Fix: OSC 2 heard when FM active when patch with FM saved on is selected
Bug Fix: Write cancelled, incorrect program name/number can be displayed
Bug Fix: Sustain pedal off kills all notes even with keys still held
Bug Fix: Updating from 1.0 causes factory programs to be pushed to user banks 9-16
Take5_Main_1.0.0.10.syx
**Known Issue: The factory sound bank locations will be overwritten with basic program when the 1.0.0.10 OS is loaded.  A factory sound bank file which will load to the factory locations is attached**
New Feature: Additional 8 Banks of program locations.  Banks 9-G can be accessed holding the bank button and pressing numeric button 9-16.
New Feature: Envelope repeat for envelopes 1 and/or 2.  Accessed in the prog-level parameters menu.
New Feature: Alternate tuning per patch.  Accessed in the prog-level parameters menu.
New Feature: Oscillator 2 filter bypass mode.  Accessed in the prog-level parameters menu.
New Feature: Sequencer start/stop from foot pedal.  Accessed in global foot function parameter.
New Feature: Vintage added as a mod destination.
New Feature: LFO 1 and 2 slew rate.  Accessed in prog-level parameters menu.
New Feature: LFO rate displayed on-screen when frequency updated and LFO sync active.
Bug Fix: Poly aftertouch messages not responded to.
Bug Fix: Program select buttons and 7 segment display not recalled correctly after compare used in write mode.
Bug Fix: If sequencer transposed to current transposition setting, record is turned on.
Bug Fix: Envelope re-trigger does not operate correctly when unison is off.
Bug Fix: Program change can be ignored if sent at same time as bank change message.
Bug Fix: Various additional UI fixes and improvements.
« Last Edit: November 06, 2025, 11:23:38 AM by gus »
Product Designer
gus
  • 293
Re: Take 5 Main OS 2.2.0.9 and Panel OS 1.1.2
« Reply #1 on: November 06, 2025, 07:57:37 AM »
Beta Take 5 Main OS 2.2.0.9 and Panel OS 1.1.2 are out now! Files and instructions can be found attached to this thread at the bottom of the post above.
Be sure to follow the outlined steps for updating. If you run into issues, please reach out to support@sequential.com and we will help you out.
1. Load Take5_Main_v2.2.0.9.syx
« Last Edit: November 06, 2025, 11:46:16 AM by gus »
