I've had my OB-X8 for exactly a week now, and had immediately encountered some unusual behaviour of the modulation lever section (I've got an open support ticket running with Sequential on this). After using the modulation lever for vibrato once, full vibrato stays on any subsequent patch chosen even with the lever in default off position. Switching the buttons off kills the vibrato, but means that the lever cannot be used again in the same power cycle. Any new patch chosen starts up with both mod lights on and horrendous modulation applied to the sound. Plus, pitch bend seems to be a semitone at max up or down, and can change during playing without me touching it!
I asked them for the most recent firmware update (1.0.0.4) which I was sent, to see if this fixed the problem. I tried two separate SysEx programs (SySex Chat / Midi-Ox) but neither communicated with the OB-X8 from my laptop. I made sure the Global settings on the OB were set to receive SysEx data over MIDI not USB, and I've made sure the MIDI in / out cables were in the right ports. The firmware version on the OB stays resolutely on 1.0.0.1
Has anyone encountered an issue similar to this, or has a fix for it they can impart please?
If the firmware update doesn't fix the problem, the synth is having to go back to the retailer which is far from ideal.
Many thanks.
