Anyone please ?
At 15 seconds you can really heard the problem, You can heard two « wave » of resonance But I press the keyboard one time … and you heard like I pressed it two time
I use a sustain pedal, and they told me than the problem can be here
Ok so thank you for all your advice. I tried without anything plugged into the synth. In ob8 envelop mode I have the « triggering latency » but not in obx mode, maybe the difference between them is the re triggering envelop ? To be sure, I sent a video to the support
Quote from: kyps on September 03, 2022, 03:08:43 AMOk so thank you for all your advice. I tried without anything plugged into the synth. In ob8 envelop mode I have the « triggering latency » but not in obx mode, maybe the difference between them is the re triggering envelop ? To be sure, I sent a video to the supportWhat was the solution. I have the same issue with mine. It is noticeable on Slow Strings patches. I am also losing voices on slow string patches. Then, when you release the chord and play another chord, at times there will be a slight sound of portamento for half a second before with quick attack.. strange.
