Global MIDI Clock Mode
« on: August 18, 2022, 05:54:27 PM »
Anybody! Stranger Things are happening to my REV2 in Global mode. According to the manual, I should have...
MIDI Clock Mode:
• Off: MIDI Clock is neither sent nor received
• Master: MIDI Clock is sent, but not received.
• Slave: MIDI Clock is received, but not sent.
• Slave Thru: MIDI Clock is received and passed to MIDI Out
• Slave No S/S (no start and stop): Receives MIDI Clock but does not respond to MIDI Start or Stop command.
Here are the Global/ MIDI Clock modes on my REV2. Shouldn't they say Slave?
1. Off
2. Out
3. In
4. In Thru
5. In No S/S
I want to Slave the REV2 to a Korg Kronos sequence, but do I have missing midi clock modes? I have always been able to Slave the REV2 to a sequencer or DAW for arps and LFOs. I did reset my globals. The REV2 is set to receive on MIDI ch. 16. Could that have something to do with it? Thanks.
BT
  • 125
Re: Global MIDI Clock Mode
« Reply #1 on: August 19, 2022, 12:44:39 PM »
Hi there, Logic Song.
'Slave' was changed to 'In' in an OS update after the manual was written. The MIDI functionality is otherwise the same.
I hope this helps!
« Reply #2 on: July 14, 2025, 08:27:08 AM »
Viva la Prophet Rev2 as it will never be a slave! :)
Actually, In and Out describes this behavior better with less symbols.
Thank you, I was looking how NOT to start Sequencer and just receive MIDI clock, it's 5th mode: In No S/S
