- more range on the transpose. +2 when you hit either down or up a second time.
- also save transpose per-preset instead of just globally (pardon me if this is already done, but couldn't find it)
Yes! For the above (and I'm going to use my UBXa which does the above and the Bend suggestion below better), press the Transpose up or Down on the OB and you get one octave. With the UB, press once... same as OB, press
again and you get an additional octave, LED is solid after 1 press, flashes after two. Simple, and much greater range. Why so limited on the OB?
Second request is with the Portamento Bend. The OB is again too restricted. Why all the pre-set options?? (-12, -11.5, etc.). On the UB they made the Bend option far more capable... an option to turn Bend On/Off, then hold shift and turn the Portamento knob... you can go like three octaves -/+ unlike the (64 is it?) bend options on the OB,
. I can start the sweep on a very low note and glide all the way up to the key(s) pressed. The OB isn't even close. So please remove all those "pre-set" options, and just allow us to set the parameter in a single page 2 setting with a far greater range (three octaves?). If I'm missing something or doing it wrong, by all means let me know!
