« Reply #2 on: August 17, 2022, 01:28:23 PM »
Hi, is it possible to have pan assigned by note number across the keyboard? So it progressively scales the pan so the extreme left hand notes are in the left channel and the extreme right hand notes in the right channel? I can assign it in the mod matrix but they can only be set positive or negative, not both which gives a different result. Thanks!
For some reason this is somewhat quirky! The best I can achieve, (using a single layer), would be
to set two slots in the mod matrix accordingly:
Source Amount Destination
DC -64 Pan
Note Number 127 Pan
The DC offset allows the positive modulation of the note number to pan a played note from left to right
according to note number rather than being biased either to the left or right.
Hope this helps!
Sixcontrabass: - Prophet 10 Rev4, Prophet 12, DSI Tetra, ESQ1, Yamaha FB01, Korg 05R/W, Cheethah MS6, Cheetah SX16, EMU e5000 Ultra, Roland Super JV, Novation A Station, Waldorf Blofeld, Creamware B4000, Creamware PRO-12 ASB, Behringer Dimension D, Neutron, Pro-1
