Hi All,
I've cross posted this at gearslutz as well... Am I going mad, or just being incompetent?
I'm wondering if this is normal behaviour, or if I've got a fault...
When I've got my P6 patched into my 01v via the main L/R output, with the master pot on the P6 set to max, and the input padded by -20db, I'm hearing distortion on any sounds played. (All my other bits of kit I usually have outputs set to max to make sure the signal is loud and to eliminate any noise floor from interference.)
If I have my cans plugged into the headphone out on the P6, I can't have the master too loud, but about 1/3 to 1/2 way I don't hear the same distortion, and the signal / sound is perfectly clear and un-distorted.
So If I turn the pad switch off on the mixer, and leave the P6 master at about 1/2 way I get a clear signal.
I've tried different inputs and cables, but get the same result.
Any ideas anyone? Or am I driving the P6 too hot ?
