How to avoid inconsistency on sounds by Yorgos Arabatzis:
1) Use Wave Reset
2) Mess around with various combinations on Delay parameters for Pitch,Filter,VCA or Aux envelopes.A setting of 1 will do the trick.Also play around with VCA attack time.
4) Using the self oscillating filter is unstable as Chris stated unless sound assigned to a voice.Try to use the waveforms of OSCs 1-4 instead if you don't assign a sound to a voice.
5) Assigning a sound to a voice can help also but produces a small click to the sound.
6) Take it easy on the Feedback.Settings beyond 80 create unstable environment.
7) Every tiny change you make in Tempest's envelopes counts so it's a mater of sweet spot in them.A spectrum analyzer can indicate these changes.
This and many other tips here:
http://forum.davesmithinstruments.com/index.php/topic,78.0.html
