Global setting "Local Off" not working ?
« on: May 13, 2022, 06:09:58 AM »
If I set up local to Off, it still responds to knobs.
Re: Global setting "Local Off" not working ?
« Reply #1 on: May 14, 2022, 12:41:30 PM »
With local control turned off it stills sends the data to the midi out. If it is connected via midi or usb then you probably have a midi loop happening.
« Reply #2 on: May 17, 2022, 01:26:26 PM »
Thanks for the answer (I missed it).
You are right, I had unintentionally checked a box on my MIDI interface software, that enabled forwarding Midi out to in.
Works as expected now !
