Arpeggiator and Sequencer don't run anymore!
« on: May 12, 2022, 04:36:19 AM »
My OB-6 is about 4 years old.
No matter if I use internal or external clock: The Arpeggiator and Sequencer don't run anymore.
(The clock-bpm is displayed.)
Hoping for help!
« Last Edit: May 12, 2022, 04:57:25 AM by Kai-vD »
gus
  • 139
Re: Arpeggiator and Sequencer don't run anymore!
« Reply #1 on: May 12, 2022, 09:46:21 AM »
I would recommend running through the troubleshooting guide at the top of the OB-6 thread if you haven't done so already. It will lay out a few basics to try. To start, make sure you're OS is up to date. From there do a Global Reset, disconnect everything except power/headphones, and see if you still have issues. Good luck!
« Reply #2 on: May 12, 2022, 10:09:01 AM »
Thanks, that was the first things that I already did:
The OS is 1.7.4 and the global reset didn't change the issue.
« Reply #3 on: May 12, 2022, 10:39:35 AM »
Just to try something I did the update procedere again to OS 1.7.4 - no change of the issue.
When I set the arpeggiator to "on" and press a key or several keys nothing happens.
(Pressing a key several times after another the note is once in a while audible.)
Is my unit broken? Must I send it to a repair shop?
« Reply #4 on: May 12, 2022, 10:56:04 AM »
After I tried the factory reset again - it works now!
