would u mind to explain what u did? I also got these two sitting next to me and I'm curious.
I just plugged a MIDI cord from the MIDI out of the Pro3 to the SR-16 MIDI in.
When I press Play on the Pro3 the drums play along.
- Though I did notice you need the SeqParams/Restart to be set to "On"
(Also, in Global/MIDI, set MIDI Clock Mode:Out, MIDI Clock Cable Out:MIDI 1, MIDI Out Select:MIDI 1)
That should work with any drum machine, I think.
It's just fun to have a drum beat start up with the sequence. But the old drum patterns on the SR-16 aren't that interesting, and I'm a *terrible* drum programmer.
[Edit: I was also thinking you could probably do something like this with 2+ Pro3's. And get more voices in a 'live' sequence. But I don't know that it would change sequence parts when you pressed "B" or "C", etc.]
