For example,
I'm running my P6 as a slave to my drum machine. I have a sequence going in time with the drums. The chorus is coming and I want to cue up the next sequence on the P6 which is saved on the next patch.
When I hit the next patch button, it changes automatically and is not in sync with the MIDI master/drums and is impossible to get lined up perfectly.
Is there a way to set the P6 so that when I change patches, the next sequencer wont start until the end of whatever phrase is happening?
The Keystep Pro is an example of this, when you're running a sequence and you push the next sequence button, it doesn't actually switch over until the end of the current phrase.
I realize the patches are not sequence dedicated, but they have a sequencer incorporated, which starts automatically with MIDI, therefore if there isn't already an option to sync changing patches with saved sequences, there should definitely be one.
