Hi all,
I just took delivery of a new Prophet 10 keyboard (although serial number of around 1,000 meant retailer had actually had the unit in stock for 6+ months). To be clear, it was a brand new, sealed unit.
As the unit was badly out of tune I tried the Tune process, but it always freezes at the same point.
I have followed the Tune instructions in the manual, and have also followed the advice on the Sequential forum at
https://support.sequential.com/hc/en-us/articles/4407479669779-Prophet-5-10-Keyboard-TroubleshootingThe firmware is updated to the latest version OS 2.0.1 and Panel OS 1.1.1
I have tried Reset global parameters: hold RECORD and press GLOBALS.
I have tried B. Wheel Calibration.
I have tried Clear Calibration: Hold RECORD and press TUNE.
No audio or MIDI leads are inserted in the rear of the synthesizer.
Whenever I run the Tune process by pressing the Tune button, it hangs at Step OA4, program light 2 for a few minutes, but eventually makes it through this step. It then hangs at Step Ob4, program light 3 for anything from 5 to 30 minutes+. However, when it gets to Step Ob4, program light 6, it just hangs indefinitely, even having left the synthesizer on for hours - the tuning routine never finishes once the unit is at its operating temperature, which seems to be 45°C (display says 45C). My home studio temperature is about 18°C. The only time the process once eventually finished was when I pressed Tune when the unit was cold, having been switched off for some time.
I have also checked that this is not a broken voice issue - it’s not I as can still play 10 notes before the first played note is “stolen” to play the 11th note.
Has anyone else experienced a similar issue and been able to fix it - if so how?
Many thanks for your comments.
