P6 USB midi suddenly not working?
« on: February 22, 2022, 01:18:00 PM »
Very strange.. my P6 is no longer showing up as a connected active USB device on my Big Sur Mac Pro. Had no problems whatsoever the whole time I've owned it. Troubleshooted by connecting a known working USB cable going to a P5 that shows correctly on my Mac to it, and nothing.. I checked my global MIDI in and out setting on the P6.. everything looks correct for USB.. The P6 OS is 1.6.7.Anyone have any thoughts on what might be wrong?
thirteen_engines
  • 181
Re: P6 USB midi suddenly not working?
« Reply #1 on: February 23, 2022, 08:28:34 AM »
I had something like this happen to my Korg Prologue. My Mac one day just refused to talk to it via usb. For this and other reasons, I sold it. Your problem sounds eerily like mine with the common factor being the Mac. Maybe you could try deleting the usb midi device in Audio/Midi (without the P6 being hooked up). Then connect the P6 and turn it on. The usb midi device should return and perhaps be functional again.
Keith
« Reply #2 on: February 24, 2022, 08:38:39 AM »
I had that happen with another USB-midi device once and Keith's suggestion solved it for me. I've stopped using USB for midi synths altogether though because it almost always causes a ground loop hum in the background.
« Reply #3 on: November 10, 2023, 09:24:41 PM »
My Prophet-6 desktop just stopped receiving MIDI IN via a MIDI Cable. I checked it with 3 different controllers and several different working cables. The sequencer produces sound so everything seems fine except MIDI IN. I reset the Global parameters but haven’t done a hard reset if that’s even possible. Any ideas greatly appreciated.
Thanks.
« Last Edit: November 10, 2023, 09:51:17 PM by Blacklab88 »
