midi clock routing question
SeleN
« on: January 15, 2022, 04:11:10 AM »
it’s probably a nonsense question but i like to know if the pro 3, when set as midi clock slave to my daw and receiving the clock thru usb, can do a handover of the clock to its midi thru channel, but with its arpeggiator still clocked to the incoming signal ? setting: global->midi->midi clock mode->in thru and midi clock cable out set to midi all. only in this setting the pro 3 transmitts clock signal right ? but then no arpeggiator or sequencer function is avaiable … page 96/97 in the manual…? also midi channel is set to all, clock cable in to usb, midi out set to midi all…
i‘m trying at passing the clock to my prologue (i am aware of the clock tightness problem but i have my reasons…)
SeleN
Re: midi clock routing question
« Reply #1 on: January 19, 2022, 01:53:07 PM »
Ok. seems to be not very user centered...
