How do I alter midi channels
« on: January 11, 2022, 08:42:10 AM »
Hi
I was wondering if layer A and B can be on different midi channels and how do I change the volume setting for each individual layer.
Thanks.
maxter
  • 419
Re: How do I alter midi channels
« Reply #1 on: January 11, 2022, 10:01:11 AM »
In Global settings, I think you set it to Multi, and then the "Midi Channel" selection selects a channel for Layer A, let's say you chose #5, Layer B will then be on the succeeding channel, in this case #6. If you set "MIDI mode" to CC, not NRPN, it should be as simple as sending CC#7 to control volume on each Layer, on their respective channel.
Not completely sure, as I never set mine up like this, but off the top of my head that should be it.
« Reply #2 on: January 11, 2022, 01:59:52 PM »
You can change each layer's volume with the "Misc Params" button just below the display. Program volume is the first parameter.
Hi
Thanks.
