Prophet 6 OS 1.6.7.
Prophet 6 OS 1.6.7.
« on: December 13, 2021, 05:21:50 AM »
I've experienced a weird problem a few days ago trying to update from 1.4 to 1.6.7. via midi ...
it all went fine first , then got stuck before finishing the update , and the Prophet 6 is stuck since then ...
I wrote to DSI and they told me to try to power up in bootloader mode ( wich i did ) but it doesn't even power on in bootloader mode, it's just frozen... so i'm waiting for a new answer from the technical support.
If someone has an idea ?...
Re: Prophet 6 OS 1.6.7.
« Reply #1 on: October 28, 2022, 07:15:56 PM »
Hi, did you ever find an answer to your question or get it fixed?  I'm having similar issue...using Midi OX on windows, it goes through the process of sending the sysex, but then during the second phase, as it counts down from 8 to 1, it stops at 5 (with a 3 in the upper left window).  Tried several times and it always stops there.
