In "16 Beats" mode, I am unable to use the Copy button to copy *to* the currently selected beat, even when playback is stopped. Is this expected?
Main OS: 1.5.0.2
Voice OS: 1.5
Panel OS: 1.3
Sam OS: 1.1
Repro steps:
- Select "16 Beats" and "Pads" (the Screens mode doesn't actually matter, but this makes it easy to see)
- Select Beat 1 and begin playback
- Hold the Copy button and confirm that the parameters across the top are: AB->AB, On, On, On
- While holding the Copy button, tap Pad 2 and then Pad 1 (to copy Beat 2 on top of Beat 1)
- Note that the selected pad name has not changed.
- Stop playback
Expected: Pad 1 would now hold Beat 2
Actual: Pad 1 still holds Beat 1.
If, instead of the "Copy" button, you use "4. Copy Beat" under the Edit menu, the beat is always copied to the destination pad. If playback was enabled, it is stopped by the copy (regardless of whether the destination pad was playing). That behavior is fine. It's just weird not being able to use the Copy button on the current selected Beat when playback is already stopped.
