Tempest Main 1.5.0.2 and Voice 1.5 - Bug Reports
Started by cbmd, June 27, 2016, 12:15:05 PM
1024 Replies 1,405,755 Views
Thom
Commerce
Quote from: Roger_Linn on August 24, 2016, 01:22:38 PM
Hi Thom--
1) I was able to reproduce it here. It occurs when switching during play from a beat with more than 192 ticks to a beat with 192 or less. It occurs using any BtQuant value; if the transition to the new beat lands on a tick containing events, they don't play. Thank you for finding this.
2) We've already fixed the slow scroll of files within a folder. We'll release a new beta once we fix a few more things.
3) This problem was related to the slow scroll of files within a folder (#2) above. Fixing it fixed this also.
Excellent, thanks for following through Roger & co!
There's magic in the 'pest, love it :)
cbmd
Global Moderator - Sequential
Full Member
The issue with two sounds not being able to be triggered at the same time seems to be resolved by resetting the Tempest's system parameters.  Would users whom are encountering this issue please reset the system preferences and check whether the issue is still present?
Product Designer
Roger_Linn
Jr. Member
Quote from: cbmd on August 26, 2016, 01:04:46 PM
It worked for me! Good call, Carson!
Yorgos Arabatzis
Moderator
Full Member
Confirmed fixed here also thanks Carson!
molotov
Commerce
Hi guys, just got round to loading the beta.
For me, everything seems to have slowed down considerably in terms of loading, saving, naming and browsing the UI  :-\
I've tried reloading the OS and voice etc a few times and recalibrating everything.
Yorgos Arabatzis
Moderator
Full Member
This is happening due to the new file system handling things alphabetically.Roger said they're working on it.
Quote from: molotov on August 28, 2016, 05:27:41 AM
dekalboy
Commerce
I have noticed 3 mains bugs for the moment .
LATCH button for the sliders  :
before the update you have to press SHIFT to engage it with this update pressing SHIFT will change FX1to FX3 and FX2 to FX4. So it is inverted compared to the old OS version.
Loop screen :
Bug when you loop the screen in 8,8T,16 QUANT the overall sound of the tempest is muted. In 32 and 32T quantization all is ok .
Bug with the ROLL in beat mode  :
suppose you engage the roll button in beat mode and then press the beat to cancel the roll and you keep the roll button engaged. Then, you start to tweak the beat by turning pitch, attack decay and so on ....At this point if you want to reload the beat to initial stateby pressing its corresponding pad , the beat is not reloaded unless you need to disengage th ROLL button .
Roger_Linn
Jr. Member
The slowness when browsing files within a folder is a bug that has already been fixed. The slowness when changing between folders will still be there because every time you display a different folder's contents, it must be alphabetized, just as on mac or Windows.
Yorgos Arabatzis
Moderator
Full Member
Another UI bug here where some sound names getting dissapeared as i scroll with softknob 4 when loading sounds.Also if i try to save these sounds their name is blank.Ghost in the machine :P
Roger_Linn
Jr. Member
Quote from: dekalboy on August 29, 2016, 01:52:14 AM
Hi dekalboy,
The function of the Latch buttons is set by 'System button > UI Preferences screen > Latch Button Behavior' to either of the behaviors you described. I suspect you previously had this set to "Shift Switched" but once your reset the System parameters in order to fix the recent , this was reverted to the default "Normal" option.
Loop screen :
Unfortunately, I can't get that to happen here. Is it possible that the portion of the beat you are looping contains no events? If not, can you please tell me how to clearly repeat the problem using one of the factory projects?
Bug with the ROLL in beat mode  : [/b][/u]
The problem here is is how you're turning off Roll. If Roll is on, the correct way to turn it off is to press it again. Or you can hold the Roll button and Roll will only be active only as long as you hold it. When using the Roll in this way (and as described in the manual) everything will work correctly. Similarly, the correct way to undo all Beat-wide sound changes made while in 16 Beats mode is to select Sounds in the Screen section then press the "Revert" soft key. This is also how to undo sound changes for a single sound while in 16 Sounds mode.
Roger_Linn
Jr. Member
#130
Quote from: Yorgos Arabatzis on August 29, 2016, 05:14:16 PM
Hi Yorgos,
I have not been able to reproduce this here. Can you help me repeat it on a factory project with instructions on how to make it happen?
beatmaker
Commerce
#131
Hi Roger, hello everyone!
In playlist mode, while the sequencer plays you can no longer scroll down the list with encoder 1 above the screen. Before this beta you could go up and down that list with the first encoder (step) and even change the number of repeats per step, or the beat for that step etc while the sequencer was playing. It was a feature that i used and i really liked, sure it wasn't meant to be left behind?
Roger_Linn
Jr. Member
Quote from: beatmaker on September 01, 2016, 04:20:48 PM
Hi beatmaker--
The ability to edit playlists while playing was removed a couple of beta releases ago. It was necessary to fix the playlist freeze problem that was listed on the petition. The problem is that editing the playlist while it plays requires a lot of internal recalculation.
However, I thank you for finding a bug: the Step soft knob should still work while playing playlists because it merely scrolls through the list and doesn't require recalculation. We will be fixing this. Until then, you can do the same thing with the Up Arrow and Down Arrow keys, albeit more slowly.
Yorgos Arabatzis
Moderator
Full Member
Sorry for the late reply Roger,
It seems the latest beta has fixed this issue.I'm not getting any blank names..
Quote from: Roger_Linn on August 29, 2016, 05:34:26 PM
Hi Yorgos,
Roger_Linn
Jr. Member
Quote from: Yorgos Arabatzis on September 02, 2016, 05:35:14 AM
Thanks.
gonzaloco
Commerce
Hello , this is my first post .
I´ve just updated Main_1.4.2.5b .
Can´t record two notes simultaneously (on 16 tunings mode) . Resetted SP and the issue is still present.
Anything else i can try?
Thanks.
Roger_Linn
Jr. Member
Quote from: gonzaloco on September 02, 2016, 12:07:42 PM
Thanks.
Hi gonzaloco--
I'm afraid Tempest does not record polyphonic tunings, nor has it ever. When using 16 Tunings mode, you are able to play two or more tunings simultaneously but only one one instance of a specific sound pad can be recorded at one timing location.
The bug that had been reported--and which is fixed by resetting System parameters--was the inability to play two different sound pads on a single timing location, not two tunings of the same sound pad.
beatmaker
Commerce
Quote from: Roger_Linn on September 01, 2016, 05:57:16 PM
Hi beatmaker--
Cheers for the reply Roger. It's all good. I understand that modifying the beat per step or repeats per steps involves recalculation. No worries. Right now you're right you can only move up and down the playlist with the arrows. Would be great to be able to scroll with the step encoder like before without changing beats or repeats which would freeze it. Even though, i must tell you when the feature was there i always used it to adjust repeats per step while i listened to my song after i made it but no probs that can be made offline as well. i am great full enough the song structure is there which is probably one of the best i worked with.
HT
Commerce
Hello fellow pesters,
More of an observation than a bug, deleting sounds in quick succession causes screen artifacts. Files still get deleted so no mither to me.
No issues so far but would like the ability to drop in and out of a playing playlist. That aside I'm happy with this beta.
Roger_Linn
Jr. Member
Quote from: HT on September 04, 2016, 02:43:59 PM
Hi HT,
I'm afraid that can't be helped. Alphabetizing files within a folder needs to be done whenever you delete a file or change folders, and it takes a brief moment to do so, causing the delay in screen refresh that you're experiencing. However, it's generally not an impediment to normal workflow.
Regarding dropping in and out of a playlist, I assume you mean the ability to turn Playlist off and on without stopping play, for example turning Playlist off in order to vamp on the current step's beat for a while, then turning Playlist back on in order to resume the playlist from the same point. Is this correct?
