Tempest Main 1.5.0.2 and Voice 1.5 - Bug Reports
Started by cbmd, June 27, 2016, 12:15:05 PM
1024 Replies 1,405,230 Views
John the Savage
Full Member
Quote from: Nothingprd on November 27, 2025, 10:16:24 PM
Hi everyone -
I'm new to the Tempest, hope this is the correct place to post.
I'm having an issue with an abrasive high pitched noise being triggered on multiple pads...
The only thing that seems to have worked is resetting system parameters and then saving that as a start template project file.
Thanks so much,
Dave
Perhaps this reply comes too late, but it sounds to me like the compressor level was maxed on the beat or project that you were using -- which can be saved either globally per project or per beat -- and that resetting the system parameters simply set the default compressor level back to zero.
Cheers!
Nothingprd
Commerce
Thanks no, definitely not the compressor.
We found a post that describes the problem but unfortunately the suggested fixes didn't help.
https://forum.sequential.com/index.php/topic,3778.0.html
Appreciate it tho!
Yorgos Arabatzis
Moderator
Full Member
Quote from: Nothingprd on December 05, 2025, 11:49:42 AM
Appreciate it tho!
Have you got any cables plugged in apart from the main outs?
Nothingprd
Commerce
Nothing plugged in aside from headphones and power. I tried the main outs and same issue.
I actually ended up sending this one back and bought another, so I'm still in the Tempest family!
Thanks for the suggestions.
Yorgos Arabatzis
Moderator
Full Member
Quote from: Nothingprd on December 08, 2025, 11:55:05 AM
Glad you shorted it out!
