Normally I would also count myself as a 100% hardware guy too... but it's just too comprehensive technically to be that, with how I work... I want to be compact, but a 100% hardware setup would require a mixer, external FX, a harddisk recorder in hardware, and at least ONE synth to record from... it is possible, but the more technicallities I've got, the less focus I get... I can feel it even now that I settled with only the REV2, a pair of speaker, and my DAW... much less cable clutter, very much more streamlines workflow and I get a lot more sounds made right now than ever before... this is for me... ONE synth (with keys) connected directly to my RME AIO soundcard for recording, and using plugins for the FX... it's really all I need...
But I still have gearlust... still got GAS... still drool over new synths... that is an addiction I'll never get rid off, so I'll be purchasing other keyboard synths each half year... I'll just connect one of them on any given time, while the others will be stored away for next time... I aim at making scores that fit about 60 minutes, so I'll be using different keyboard synths thru such a project, just never more than one at a time... might make perhaps 3 minutes with a REV2, then evolve the end of that into the next using say; a Prophet 12... and so on.... the idea is simple: One synth at a time for simplicity, focus and dedication ![Smiley :)](https://forum.sequential.com/Smileys/default/smiley.gif)
Ah great such a different approach, nice. I am totally the opposite, working daily with advanced global corporate computer systems I want at home to get "my hands dirty" with buttons, encoders, pots, sliders, flashy LEDs, rack cases and all that jazz.
Sometimes, but not always, it takes a bit longer to get the sounds right and compose a track, but I find it 2000% more satisfactory than working with plugins on a (Windoze or Mac) laptop. Recording 12 or more stereo tracks, especially if I separate the outboard effects, is time consuming. In due course I want to be able to record 12 or more stereo tracks simultaneously. Unfortunately Linux compatible soundcards wih these kind of capabilities are very expensive.
Kind of like dreaming about Klaus Schulze setup in the 70's, surrounded by stacks of electronics
. Happily I have a loving partner, she will restrain my ambitions a bit.
Don't get me wrong... i do want to get away from the computer too... these days I hate programming arrangements... this is what makes my setup a bit different, simply because i need to go as much hardware as possible, and less computer at the same time... I do not "program" arrangements anymore, instead I record a whole track in one go, then switch to the next... actually I could as well have used a multi-track tape recorder, there is no real difference, except for the plugin system... I'm tired of cut/past/move... the reason I chose this setup is because it's both very flexible, but also very compact... i can reuse the same synth as many times as I want this way... thus I only need one really... if it was not for my GAS
Actually I've only hooked up the REV2 via MIDI to my computer because I need to program presets using an editor... that is the only thing I'll never be able to accept... programming a synth by it's front panel... I want ALL parameters on the screen at once... other than this, I don't even follow a metronome anymore... i just PLAY and RECORD... and when something must be layered, I follow the rhythm of previously recorded tracks... it's not that hard, especially with ambient music... in fact it makes the scores so much more dynamic because I can speed up and slow down when I want to... nothing is repeated, unless its done live... the compositions is much less static this way, sound much less "programmed".
So in a sense... I understand your urge to go away from the computer... I want the same, I just cannot go 100% hardware because I need the DAW as a recording medium and an FX processor... and when time comes, also mixing and mastering... but all else is hardware.
Actually the only time quantized sequences I'll have will be those that are played by the REV2's internal Arp or Gated/Poly sequencers... no MIDI tracks in the DAW at all...
But with that said... i sure admire Klaus Schultse and all his gear, and his ability to use it... point is, that there is no right or wrong way to make music, the main goal must always be that you actually DO something with what you have... that was my problem for MANY years because I kept on hoarding gear, never having a chance to get to know each instrument deeply before selling it, and buying something new, starting all over again...
