Hello,
I am using an OB-6 desktop module together with a Low Frequency Expander (LFE). The LFE utilizes the OB's MPE capabilities to provide further modulation sources. This works quite nice apart from the case I would like to use the internal arpeggiator of the OB-6.
Not sure but it seems the arpeggiator is not MPE capable as it only sends and receives on the OB-6 midi master channel. Means when the OB-6 receives midi info from an MPE source (like LFE) it ignores all midi channels apart from the master channel which basically means it does not play the arpeggio. Any thoughts please?
Thanks,
Uwe
