Not really an issue, just wanted to verify this was normal:
I noticed stepping in the glide, depending on which alternate scale you're in.
For example, if you choose alternate tuning slot 12 (factory), then put glide to full, play a note, you can hear the glide stepping/stopping on each note briefly until it reaches the note played.
I thought glide was typically a smooth voltage to the next played note at a given rate.
Again, no big deal! Just wanted to make sure this is normal. Thank you.
