OB 6 USB midi doesn't work
« on: October 23, 2021, 04:36:31 AM »
iīve tryed to connect with midi USB, and it worked fine to play in the midi notes, but when I played the midi track, the OB 6 didnt play/recived the midi infomation??
The same setup works just fine with my Moog sub37.
I use Ableton 10.
Check the global setting (all midi channels, USB in/out
Re: OB 6 USB midi doesn't work
« Reply #1 on: October 23, 2021, 09:52:22 PM »
Yep, same here. Ob6 doesnít work with midi over usb!
« Reply #2 on: October 24, 2021, 10:37:45 AM »
But can that really be true the it doesnít work? Or is there any way to solve this?
« Reply #3 on: October 24, 2021, 12:35:13 PM »
Is there a Global MIDI control to choose whether you want to use MIDI DIN or USB for MIDI communication?
« Reply #4 on: October 25, 2021, 12:47:21 AM »
Donít you need to make sure MIDI receive is switched on? You may have it set to transmit only.
Are you on the latest firmware?
« Reply #5 on: November 10, 2021, 01:35:29 PM »
Sorry for the late response.
Yes, the global is set to USB. And tryed all the Global "Midi Clock" dosent work???
« Reply #6 on: November 10, 2021, 01:39:31 PM »
Midi receive (midi clock, right?) is switched ON
Firmware is. 1.5.5
