Is this new in 1.6.7 or are you just confirming that it's still present in the latest?
I don't know if the Bug is also present in previous versions. I have just one P6 with the OS 1.6.7 and on this unit I discovered the Bug.
I've never figured out how to effectively use ring mod in poly mode. Can you point me at any good examples?
I use it in Poly Mode with a low modulation Frequency (1-16) and I am playing the Bass notes with the left Hand, so the Modulator will always be rather low.
With this one can get nice effects, IMHO. But this works just on the OB6 where the modulator is always locked to the lowest Key
Sadly on the P6 such things are not possible, because due to the Bug the Ring Mudulator, the modulation frequency quite often looses track of the lowest key and locks to a higher one, which sounds annoying.
If you want I can upload a demo and link it to demonstrate how it sounds on the OB6 without the Bug and on the P6 with the Bug.
br
Gerhard
