Hi guys,
I hope all is well.
I was just wondering, (Noobie-)
Is it possible to trigger the sequences (ABC, +D) another way aprt from using the front panel buttons?
and,
Is it possible to copy note data from one track to another?
Using the method described in the manual, I can copy all other info e.g. automation data from one track to another but this way doesn't include the notes. Using the screen to edit is fine but is there another way?
Last but not least,
I understand one can copy sequences around within the current program,
Is it possible to copy a sequence 'between' programs e.g. 'B from one program' and paste it into 'D' in the current program?
The manual mentions using SEQ LOCK and CUE PGM to achieve this.
SEQ LOCK locks the sequence, CUE PGM enables cueing a sequence, neither of them copy a sequence?
Is it possible? IDK..
Does any of you guys use the Pro 3 editor and the PlugSE?
thank you guys,
Ben.
