MIDI Param Send is Off, but volume still sends CC 7
« on: August 30, 2021, 09:38:09 AM »
In the globals, I set MIDI Param Send to Off, but MIDI Monitor verifies that turning the master volume knob is still transmitting CC 7 Channel Volume (coarse) to my other synths. Am I missing something?
  • 1417
Re: MIDI Param Send is Off, but volume still sends CC 7
« Reply #1 on: August 30, 2021, 05:25:56 PM »
Maybe the volume knob isn't considered a "parameter" for the purposes of this global setting? If true, that seems real nit-picky, but it's all I got.
Pro 3 #1640
Pym
  • 181
« Reply #2 on: August 30, 2021, 05:36:52 PM »
Master Volume isn't a param, it's a global control which holds even as you change programs. Program volume is saved with your program and that won't be sent, pg82 of the manual
Sequential
« Reply #3 on: August 30, 2021, 07:53:26 PM »
OK, but how does it make sense to always transmit CC 7 to the MIDI hub once the user has turned a setting named "Send MIDI Param" off? It's certainly not universally desirable behavior to have all synths' volumes slave to the Pro-3's.There should be an onboard way to suppress that.
