Take 5 Firmware Update - Feature Requests
Started by creativespiral, August 24, 2021, 09:49:03 AM
204 Replies 581,965 Views
Elric
Full Member
Peak Oil
#100
Quote from: xoxo on July 08, 2022, 12:57:42 AM
the volume pot sending CC7 even parameter send is off is bugging me a lot, have now put a hardware midi filter box behind it to prevent connected synths to go silent, when I don't want to hear T5 (same with PRO 3)
I just noticed this, this a HUGE problem.
One of my Pro 3s is turning down the other one. (What's this Cc7 thingy?)
This took me a couple of hours to find.
Boo. Not cool.  :/
:Elric:
Elric
Full Member
Peak Oil
#101
This is what I was working on...
Attached File:  123k mp3 version.
The wav file is 3.7 megs.
:Elric:
Jorb
Commerce
After about 6-months of regular use, what I would really like to see (hope these are all reasonable!) :
1. An option for on screen parameter values. Values only would be fine if that's what's possible, but parameter names for the effects section would be helpful to me.
2. A program setting for LFO 2 to be mono / global. Poly LFO's can often feel to busy.
3. One-shot LFO setting.
4. A way to smooth / slew the sample and hold setting of the LFO's. Either a program setting that can slew all shapes, or one that swaps between a smooth or choppy sample and hold.
5. Envelope Looping.
Cheers all, Take 5 is a great keyboard and I look forward to any future updates.
Elric
Full Member
Peak Oil
#103
Quote from: Elric on July 09, 2022, 09:53:29 PM
Boo. Not cool.  :/
And of course, that was incorrect global settings on my part, at least for the setup I'm trying. (I can turn MIDI Param Receive [and Control Enable?] off for the other synth.)
Here's a (partially related?) pretty good write-up of the difference between CC and NRPN I found while re-configuring my setup.
https://www.reddit.com/r/synthesizers/comments/6w8j6v/nrpns/dm6k5fm/
And, just for fun, here's v4 (3b, haha) of the "what I was working on" above.
:Elric:
Elric
Full Member
Peak Oil
Quote from: Jorb on July 11, 2022, 01:32:24 PM
Hey Jorb!  - Welcome.
I've seen a few of your vids. Decent stuff.
Question on the above. -  ...Than why is your last Take 5 video a "first impressions" video from 7 months ago?
...Just prompting you.  :D
(I'm a Pro3 owner/fan. But would love to hear more from the Take 5.)
Cheers
:Elric:
Jorb
Commerce
#105
Quote from: Elric on July 14, 2022, 10:55:33 PM...Than why is your last Take 5 video a "first impressions" video from 7 months ago?
Well, I recreated the prophet 5 patches on Feb 8th : https://youtu.be/6Al-sB6-smw
The full take 5 review went up today, 50 minutes long. Just because you asked, of course ;)
https://youtu.be/qt9dnvXx73o
bennyblanco
Commerce
Hi guys! Having issues with the pitch and mod wheels of my Take 5. Quite often they start changing values on their own, especially the pitch gets changed usually with a whole note. I did clear the calibration and then reset all back again, the mod wheel seems to be fixed after that, but the pitch wheel keeps changing the tone. This needs to be taken care of.
Apendica
Commerce
Hey, if this interests you, this is a track I made with only the Take 5 for all layers, everything you hear it the T5, aside from percussion.
https://soundcloud.com/apendica/escaping-belial
meowmeow
Commerce
Any idea when we're getting a new firmware? It's been almost a year since release and since this thread started. What is taking so long?
synthboy
Commerce
Quote from: meowmeow on July 20, 2022, 12:57:27 PM
Maybe Take 5 will be abandoned like AS-1 once was.
Still two great synthesizers as they are but both deserve better.
Checking here every week and still hoping for an expanded patch memory :(
Apendica
Commerce
Quote from: synthboy on July 21, 2022, 05:41:25 AM
It has been confirmed on Gearspace that the update is currently being worked on  :)
cameron87
Commerce
Hi, I've been having a great time with the Take 5. So many beautiful and fun sounds. Here are a few features I'd be keen to see:
  • On screen parameter values + initial preset value (the led dot is sometimes hard to find).
  • Extra envelope routing option: Env 1 = Aux and Env 2 = Amp.
  • Envelope looping.
  • Less subtle filter drive? Maybe I'm missing something, but it is hard to notice a difference sometimes. However, I have started to notice that it does give very fine control of the filter when it is modulated with audio/filter out. Unsure of what's best here.
Looking forward to the update!
bleepbloop
Commerce
Quote from: cameron87 on August 08, 2022, 03:58:26 PM
A positive of the filter drive is that it smooths out high resonance levels on the filter which can be useful when you want the grittiness of it but not the sharp self-oscillating peak.
alan_take5
Commerce
Can you elaborate on how this fine filter drive modulation control works? I agree it's very subtle as basic drive, but it does generally compress resonance, which can be useful, I guess.
cameron87
Commerce
Quote from: alan_take5 on August 10, 2022, 01:42:58 AM
Basically, I noticed that drive reduced the warbliness(?)/distortion when the filter was modulated by audio out with resonance at max. I'm thinking that relates to what you mentioned about resonance compression?
As an example, with an init patch, modulate cutoff by audio out by 127, set cutoff to about 11 o'clock, resonance max, drive minimum. Play and hold, say, C major. Reduce the cutoff until you get a weird warbly effect and then increase the drive to tame the craziness. Hopefully that makes sense? Point is – drive seems to be very useful for carefully taming those kinds of wild high resonance sounds, but on its own is very subtle. I guess I'm torn about whether I want a change or not :)
kpatz
Jr. Member
After watching/reading OB-X8 reviews, a nice addition to the Take 5 would be to make some of the more commonly used Program Menu parameters directly accessible with a button+knob combo (like we have for Unison Voices now).
For example, hold Program+turn Drive to adjust filter keytracking.  If they also add the oft-requested display of parameters while editing them, the screen could show what you're editing when you hold Program (or whatever button they assign as the shift function) while turning a knob.
Essentially this would work similar to the "page 2" functions on the OB-8/OB-X8.
Another enhancement that would be nice:  hold an Envelope Velocity button while turning Amount to set the amount of velocity response.
alan_take5
Commerce
Quote from: cameron87 on August 12, 2022, 01:27:06 AM
Ah yes, I see. Also, is it an analog control, can it even be updated by firmware?
Elazul451
Commerce
Do we have a rough timeframe/expected feature set for the update? It's been a year since launch now and I'm still wanting for a one shot/non-looping LFO mode and some minor bug fixes.
sloopins
Commerce
One other request—would love to have the chorus, flanger, and Oberheim-style phaser from the Prophet 6. Those all sound much nicer than the ones currently loaded on the T5 (especially the OB phaser).
Xenox.AFL
Commerce
To be honest, i stopped thinking about any new features and updates...
I own the Take5 since the first day it was available, i like the machine and i play often with it but after nearly one year, no single update, that means for me that Sequential has no interest in any new updates or features...
That's why i use it how it is till the date i'm selling it. And it looks to me that this date is coming soon...  :(
Frank
