Hi All, could use some help if possible.
I just transferred 50 presets into U4 1-50 via USB Sysex Librarian and my Rev2 is acting funny. I use my Rev2 in Local Off/Midi Control On mode and route the midi out to a Bastl midi looper which then routes back into the Rev2 Midi In. Worked fine, until I added some presets using Sysex.
For some reason, when in Local Off/Midi Control On things don't seem to work properly. Namely, if I try to change a program or bank, it will show bank U- or F-# and the program P-# change, but the name of the patch does not change nor do any of the sounds. So it is showing a program change by number, but seems to be actually stuck on the program it is on when the synth is powered up.
If I unplug everything from the synth, and just power it up in Local On, it appears to work fine. This is obviously not what I want to use the synth for though. Anyone have any ideas?
