DC as a source
DC as a source
« on: August 13, 2021, 02:48:42 PM »
What is done with the DC as a mod source?
Re: DC as a source
« Reply #1 on: August 14, 2021, 02:28:32 AM »
Itís a fixed offset. For example you might want to push an oscillator into a particular spot in the stereo field so youíd apply DC as source and Pan as destination.
Re: DC as a source
« Reply #2 on: August 14, 2021, 12:38:36 PM »
Like Quatschmacher said itís a source of voltage that can be used to offset parameters.
A simple example is offsetting an LFO that is modulating a filter. The DC can nudge the LFO over so that the LFO is unipolar and so not effecting the lower end of the filter.
Or letís say you have a sequence running and want to have one oscillator switch up to a fifth in a performance. Just set the DC to the VCO to bring it up a fifth in the mod matrix but then turn amount to 0. In the sequencer route a mod lane to that Mod Amount to 100%. Now run that sequence and youíll hear it play with that VCO up a fifth. Then mute that lane when you want it to go back to the tonic. Since itís voltage and not just MIDI notes you can also vary amount per step of the sequencer for that old school analog sequencer sound where you had to dial in notes by ear-hand and get some slightly off notes.
Just to be clear: This would be pushing the whole audio signal in the stereo field not just the oscillator since there is just one filter that the oscillators go into and panning is post filter.
Re: DC as a source
« Reply #3 on: August 15, 2021, 03:00:05 AM »
Very true. Iíve just been outed as the person who still hasnít unboxed his Pro3!
Re: DC as a source
« Reply #4 on: August 15, 2021, 10:03:46 PM »
For shame!
Re: DC as a source
« Reply #5 on: August 16, 2021, 03:13:10 AM »
For shame!
I know. I ordered it at the same time as the P10 in late November. The P10 was on back order. I got the Pro 3 in December and it had a faulty encoder so I returned it. Then the replacement was on long back order. I got the P10 in January and opened it. Then when the replacement Pro3 finally arrived later that month, life was pummelling me hard and I wasnít mentally strong enough to face opening it and it being potentially faulty so I left it for later. That later is now six months down the line and Iím still not feeling great at all. I really should open it before the warranty expires in case it does need something, though.
