Can't turn Param Rcv ON (CC)
« on: August 09, 2021, 04:45:34 AM »
Hey guys,
for some reason, I cannot turn "Param Rcv" on CC in my OB-6 Keyboard version. If I change to CC it always switches back to OFF automatically. I can only choose between OFF and CC and if I close Global Settings it goes back to OFF - so I am not able to draw filter curves etc. in Logic and play them back on the OB-6.
Any ideas?
Thanks a lot  :-*
Luke
Re: Can't turn Param Rcv ON (CC)
« Reply #1 on: October 03, 2021, 03:09:41 AM »
I have the same issue. I only set OFF and CC in the "Param Rcv" global setting. NRPN is missing.
Also I can't turn CC on, when I do and check the menu again it is set to off.
« Reply #2 on: October 05, 2021, 02:50:08 AM »
Ah turns out it was a midi feedback issue. I adjusted a setting on my sequencer and the problem was solved.
« Reply #3 on: July 15, 2024, 03:06:30 PM »
...for some reason, I cannot turn "Param Rcv" on CC in my OB-6 Keyboard version...
Hello,
first comment on the forum, I registered because of this exact same issue. As I can see, it was never answered.
Before posting I solved it, so I will share how I did.
In my case using Ableton Live 12 on Windows 10, I switched off all the other synths to be sure that nothing was interfering with the problem of not being able to select NR in the PARAM XMIT / GLOBALS.
The problem persisted until I switched off the Roli Seablocks that I use as a MIDI controller.
Seems the Roli is sending clock outside, I will have to check why and how to change it, I don't know, but now the NR in the PARAM XMIT of the OB-6 is working and available.
« Reply #4 on: February 20, 2025, 05:18:15 PM »
Hello,
thank you, post made the difference for me  :)
