Hi all, I have a prophet 10 Desktop module and I notice the pitch bend has a very limited range. Is there a way to adjust the range of pitch bend?
Also; is there a way to assign Aftertouch to the amp funtion?
I guess the desk top works the same way as the "real" keyboard P-10, so this is what the manual says :
"To set the Pitch wheel bend range for a specific program:
1. Press and hold the freq a button in the wheel-mod section.
2. Use the group select (decrement) and bank select (increment) switches to choose the desired range from 1- 12. A setting of 1 equals a semitone. A setting of 12 equals an octave."
If nothing happens thereīs probably some settings in your master keyboard that needs to be changed.......
As for aftertouch se pages 12 , 16 , 38 and 39 in the Manual . ( Prophet-10 Manual )
Donīt know if aftertouch works with master keyboard though .... But it should , if the
master keyboard has aftertouch ......
Cheers !
