Long tuning process - Prophet 10
« on: July 05, 2021, 01:09:04 PM »
I have a Prophet 10 that I haven't started up in maybe 10 days. Since I last had it up and running we have had an extreme heatwave where I live. I started the tuning process a couple of hours ago and it started really slow. Now it's been stuck at OAb (or is it 6) for at least a couple of hours. I'm just curious if that's normal and if I should let it run it's cycle and/or if I risk anything by turning the machine off before the cycle is done and have another try?
Would be extremely grateful for any answers.
Re: Long tuning process - Prophet 10
« Reply #1 on: July 05, 2021, 01:40:13 PM »
If you have a backup of your user sounds I think you can turn it off
and try to restart it after 10 seconds or so .....    :-\
Cheers !
« Reply #2 on: July 05, 2021, 02:23:43 PM »
Cheers !
Thanks, unfortunately I don't have backup so I'll wait a little longer as it's still stuck at the same place. So that's the only risk of restarting even if the cycles not done? But does it seem normal with such a long tuning time with extreme temperature changes?
« Reply #3 on: July 05, 2021, 02:35:01 PM »
Cheers !
I've had my P5 get stuck twice during tuning. I wrote Sequential support and they suggested I clear the calibration tables. I did so and haven't had an issues with tuning since - neither the synth getting stuck during the process or my P5 needing frequent tuning. The heatwave is probably doing quite a number on those calibration tables.
Andy at Seq support also suggested I write down the readout next time the synth gets stuck during tuning, but I haven't had any problems since, and thus ain't written anything down. I do know that my 5 got stuck at two different places during its run of tuning freezes, but I can't remember what was displayed.
I'd suggest sending your info to Sequential. Sounds like a known issue and the more info they get from us, the better for all.
« Reply #4 on: July 05, 2021, 03:10:28 PM »
Cheers !
Ok, thanks. I've written them now and we'll see if they recommend the same thing. But as far as I understand it from the both of you there's not much risk in turning it off mid process if their answer takes a while?
All the best
Peter
« Reply #5 on: July 05, 2021, 03:33:58 PM »
Cheers !
All the best
Peter
Turning off, then back on has been my answer to getting the synth rolling when it gets stuck. I hope there's no danger to this, but yeah, it's good to log this possible bug with Sequential.
jok3r
  • 343
« Reply #6 on: July 05, 2021, 11:39:12 PM »
I don't own an P5/10 (yet), but perhaps Razmo's tuning routine from the Rev2 could help if your synth gets stuck:
Leave the synth on for a while (or play if it's not tooo much out of tune). Power it off again an wait for 10-15 seconds. Power on again and start the tuning routine.
This trick always works on the Rev2. I would at least give it a try an the P5.
