Okay here are all Rev3.3 patches (120) converted to Rev4.
Things to consider before putting them on
I included a Group.syx and a single patch.syx for each individual patch. Hoever all of them will allways write to Group5 on Rev4.
If you send a group syx file, it will overwrite all patches in User Group5 on Rev4. Ensure you have a good backup of that group.
Other remarks:
1. I needed to tune some parameters. If Unison switch is off, Glide will be set to 0 as Rev4 reacts differently than Rev3.
2. If Unison is on, I put Unison Voices to 5. You can change that if you like.
3. Vintage is allways set to 48. Adjust to your liking.
4. If Filter Keyboard tracking is enabled, it is getting set to "Full" for Rev4 patch.
That shall make the patches sound as close as possible to the original.
Last thing to mention is, that Patch 518 (Group1 1-1 of Rev3) is obviously incorrect in the sysex I have. It sounds like the standard BRASS sound and not like the Percussive Organ and as this is pretty much documented, it is also not like the patch sheets from the manual.
I decided to leave it in place. Anyhow Group1 is already there - so no real need to recreate it again.
Have fun.
