With Robert Hearts last post it seems there will not be any further firmware-update conc. transposing.
Therefor I try to work on an alternative using external midi gear.
I´ve analysed with MIDIOX what is going on when transposing a sequence (hold rec and press root note):
B0 63 08 --- CC: NRPN MSB
B0 62 41 --- CC: NRPN LSB
B0 06 00 --- CC: Data Entry MSB
B0 26 4A --- CC: Data Entry LSB
80 4A 00 --- Note "4A" (hex) off
I´m now struggling a little bit as when I add MSB+LSB I get a
NRPN-number of
1089.
This number is not mentioned in the Manual - I do think this is the nrpn for "rec-transpose". (as nrpn 1088 according to the Manual is "seq start/stop" this would make sense).
Could pls anybody from DSI confirm this.
If that´s the case I plan to program a midisolutions Event processor to do the transposing - should work
